Gmail receiving issues
    Sending working correctly. Config below.
    is there any HS specific firewall config required?
    Other ideas?
    2020-10-02 4:42:22 AM Error Unable to log into Gmail server: Tried to read a line. No data received. Please make sure that antivirus and firewall software are disabled or configured correctly.:Inner Exception: System.Exception: Tried to read a line. No data received. at   . ()
    2020-10-02 4:41:11 AM Error Unable to connect to POP server(1) Error: Object reference not set to an instance of an object.
    2020-10-02 4:39:36 AM Error Unable to log into Gmail server: No such host is known:Inner Exception: System.Net.Sockets.SocketException (0x80004005): No such host is known at System.Net.Dns.GetAddrInfo(String name) at System.Net.Dns.InternalGetHostByName(String hostName, Boolean includeIPv6) at System.Net.Dns.GetHostAddresses(String hostNameOrAddress) at System.Net.Sockets.Socket.Connect(String host, Int32 port) at Limilabs.Client.ClientBase.Connect(String host, Int32 port, Boolean useSSL)
ID:	1423581Click image for larger version
    Anyone? Am I missing some configuration parameters? Thanks
      Those settings look consistent with mine from HS3. Are you doing 2 factor authentication? This thread was about sending but the OP's answer was in the 2FA setup. There you can see my settings. I believe I had incoming email working at that time. I am on HS4 now and incoming email seems to be broken. Maybe there is something outside the local program which has stopped working for receiving email? I doubt it but do not know for sure.
      Karl S
      HS4Pro on Windows 10
      1070 Devices
      56 Z-Wave Nodes
      104 Events
      HSTouch Clients: 3 Android, 1 iOS
      Google Home: 3 Mini units, 1 Pair Audios, 2 Displays
        Thanks for the feedback; not doing 2FA. Just basic config. Sending has always and still works. I've just recently enabled receiving and noticed the log errors. Checked everything I could find on the forums but config seems correct. Guess I'll open a ticket with support.
          my Gmail receiving is not working, have put in a support ticket for this.
          HS3 Pro on Windows 8 64bit
          53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
          Check out my electronics blog here:
          https://www.facebook.com/RaptorsIrrationalInventions
            Hi Raptor
            are you getting similar errors as my original post above?
            Let me know if you hear back as I didn't find time to open a ticket.
            Thx.
              If this can help anyone (@raptor did you hear back from support?);
              here's how I got this working:
              seems like the basic config doesn't work in all use cases so you have to disable "use Gmail" and configure manually (see below)
              hope this helps
Name:	Capture d’écran 2020-11-26 105752.png
