Can u wire a Regular Light Switch with Line and Load???
    When the Light Switch is turned on the Light comes on but when the lightswitch is turned off the plugin receptacle goes off with it. So i need to find out if that LightSwitch is only wired wrong or if a new light switch could handle both Line and Load or if there is another solution.
    The Light Switch been asked about is 2 wire ...and powers a Light Switch ...and when turned on also powers a plugin receptacle.
    That is a common wiring method in many homes. Often to connect a lamp to an outlet which can be controlled via a light switch. Typically I see these in rooms where there is no ceiling light.
    To resolve would require an electrician (or DIY if inclined) to run a constant power line to the impacted outlet.
      If there is only one load line in the switch box then the light and receptacle are wired together as some point in the circuit. Most likely from the switch to one of them and then to the other. But they can also be tied together in a junction box (depending on how the electrician decided the easiest run) possibly in the basement?
      Easiest way to check, is to pull the cover off the receptacle and see if there are two black wires tied to the hot side. If so then the other one is going to the light. And if you can get to the light, same thing, see if there are two wires. If both have one then the hots are wired together somewhere else. If one has two, then you'll need to run another line to it the other one to get it to stay on. Hopefully the one that has two is your light that you want controlled by the switch.
        Do both receptacles turn off when you flip the switch?
        I have many outlets wired this way in my home. Typically one of the receptacles stays hot and one is switched.
          Here all of the bedrooms, living room, dining room duplex outlets are 1/2 wired to a switch and 1/2 wired to 120VAC power.
          Not liking this on all of the outlets have rewired many of them so that only one outlet is switched near a lamp.
          I did run in to an issue with the cleaning folks plugging in a vacumn to the automated UPB switched outlet a few years back. I did then label a few outlets for use at that time.
          That and went to using UPB autonomous switches and links for every 3 way switch here. (had four of them on the second floor hallway).
          Auto mator
            If you look at a new outlet plug, you will see a metal tab that jumpers between both outlets. On the plugs that have one switched and one constantly on, you will see that the jumper has been broken off. So you could just replace the outlet plug with a new one to get constant power to both outlets (though you would want to tape off the hot wire that comes from the switch and leave it unconnected to the outlet.)
