I'm sure I am doing something wrong and could use some guidance with this Jasco switch.
I have the Master Bath lights turn on at 16% when motion is detected, then turn off 3 minutes later via events:
That part works fine, but after it turns off, when I press the upper paddle to turn on again, no matter what I do it goes back to the dimmed value.
I have another event in case the upper paddle is pressed WHILE it is at 16% (before it times out).
This works as as expected, but after turning off the light, subsequent single presses of the upper paddle send it right back to 16%.
I have this running successfully with several other lights, but all of them turn on to 100%, the master bath is the only one I have turning on dimmed.
I've tried Reset Application Status in every way I can think of in the events, but maybe it doesn't do what I think it should do?
I'm kinda at a loss because I can get much more complicated things to work - this one should be simple! Any thoughts would be appreciated because my wife is even more annoyed about this switch than I am.
Annoyed wife = bad!
Annoyed wife = bad!
