Getting decent sounding (not Robot) TTS on Linux without using the cloud has always been a challenge. However, I may be on to something.
Some references I found useful.
https://levelup.gitconnected.com/ins...4-e6af16459ab9
https://github.com/mozilla/TTS/tree/dev#install-tts
I'm running a VM with Ubuntu 20.04 on it. Briefly I did this:
sudo apt-get update
sudo apt-get install python3-pip
pip3 install TTS
sudo apt-get install espeak
python3 -m TTS.server.server
There should now be a webpage available at localhost:5002 that you can test with. I would think you can send text from either homeseer or node-red since it is a server running locally. Previously if I would send TTS from homeseer it would never release the audio driver for node red to use. There is a delay between clicking speak and hearing the output of a few seconds that I assume gets longer the less processing power your server has.
Anyways, here is a link to what the voice sounds like and I can confirm that this is what it sounds like on my system.
https://soundcloud.com/user-...-and-tacotron2
I could use some help in figuring out the best way to interface this with Homeseer/Node-red though. Maybe through simple http statements?
