Hi all, I updated my HS and Z-Wave plugins the other day to HS 4.2.6 and Z-wave 3.0.9 and now I do not appear to be getting reports when multi taps are happening on my HS200's. For example I have an event in my master bedroom that says when the switch on my side of the bed is double tapped up run an event that turns on both bedroom lights. The event still works when I trigger it manually, but the double tap up is no longer registering.
Any thoughts?
EDIT: It appears that the multi tap engine within HS got hosed up after optimizing the network and a restart of HS took care of it. Not sure why it was not throwing any errors as there was literally nothing showing in the logs when a multi tap happened, but just thought I would update this.,
Any thoughts?
