Ready to be schooled on how? There's the root device and 7 child devices don't see a device created that can be used to access the current codes in the locks or add new ones. I'll do some searches to see if there are any threads describing how. Didn't think it was possible so didn't bother even looking.
Upgrading z-wave deadbolt recommendations?
Originally posted by sbwright View PostThanks so much, wouldn't have found that on my own. So all the codes that were added at each of the actual locks, do they need to be removed at the lock prior to inputting the new codes on the root device? I see that HS can't see the existing codes they show up as xxxxx.
Click the dropdown for "Choose the user code location to work with:" and if there's a code in that slot it should return something. If it shows up as XXXXX that means it might be the default codes. For the BE469's, slots 1 and 2 contain factory default codes, those are the codes the firmware will load if you do a factory reset. When I setup my locks I didn't want the factory codes there since they were not easy to remember for my family, so first thing I did is select those slots and then removed them. I then programmed new codes in their places.
If you ever do a factory reset again, the firmware will just rewrite slots 1 and 2 with the factory defaults. This comes in handy in case you sell the house and decide to leave the locks for the next owner.
Even if you've already setup your locks manually with new codes I highly recommend reprogramming them from the HS interface. That way they'll have names attached to the code slots in HS and you'll be able to create meaningful Events, ie, "If User code 1 is entered after 2am send me a text message", whereas code 1 is assigned to my kid. That way you can assign user codes to everyone in your household and know when certain people are coming home. Or assign a user code to the cleaning person and you'll have a record of when they entered.
Originally posted by Rupp View PostGuys, what's the difference in motorized vs manual throws in relationship to home automation. It "sounds" like the manual wouldn't be able to be locked remotely but I'm not familiar with this.
motorized throws are fully remote lock/unlock of the deadbolt. The two main downsides to motorized throws are:
1. harder on battery life
2. you really need to make sure your deadbolt is well lined up so that it can easily lock/unlock fully, or you risk jamming the bolt.
By the way "turn thingy" is the scientifical term for that thing, in case you were wondering. :P
regards,
Paul
Originally posted by TC1 View Post
I forget, it's been so long since I added/changed codes.
Ok this thread was the final nudge I needed (along with the temps in the 70's in December) to finally add a dead bolt to my front door. Yep, we've never had a dead bolt but had a brass handle that was keyed. A few nights ago the lock button popped out so that was further motivation to replace the handle. I went with the Camelot Satin Nickel Connect Z-Wave Plus Smart Deadbolt and Camelot Handleset with Accent Lever with Camelot Trim Our solid Oak door was a pain to work with but I got the holes drilled and the plates chiseled out. I was amazed at just how easy this lock enrolled into my Z-Wave network as I was expecting issues due to the past threads on this lock. I used Z-Tools to add a node, pushed the button on the lock and after a few lines of code the lock was added. I enabled the auto lock on the lock and added 3 new user codes and so far so good. I'm a little surprised by the size of the dead bolt portion of the lock on the interior and a tad bit shocked how loud this lock is but it's working great. Thanks for the nudge.
- Likes 1
Originally posted by Rupp View PostOk this thread was the final nudge I needed (along with the temps in the 70's in December) to finally add a dead bolt to my front door. Yep, we've never had a dead bolt but had a brass handle that was keyed. A few nights ago the lock button popped out so that was further motivation to replace the handle. I went with the Camelot Satin Nickel Connect Z-Wave Plus Smart Deadbolt and Camelot Handleset with Accent Lever with Camelot Trim Our solid Oak door was a pain to work with but I got the holes drilled and the plates chiseled out. I was amazed at just how easy this lock enrolled into my Z-Wave network as I was expecting issues due to the past threads on this lock. I used Z-Tools to add a node, pushed the button on the lock and after a few lines of code the lock was added. I enabled the auto lock on the lock and added 3 new user codes and so far so good. I'm a little surprised by the size of the dead bolt portion of the lock on the interior and a tad bit shocked how loud this lock is but it's working great. Thanks for the nudge.
Yeah, I've never had a problem including these locks, and I'm using the older Z-wave 300-series ones. The folks having problems don't understand how Z-wave works (it's not plug n play when it comes to locks) and have their network built out properly to support locks (ie, beaming nodes near the locks).
