Hi.I can't get the leviton dimmer to pair with HS.
Manual says hold the dimmer pedal for 7 sec and tap again.LED on dimmer blinks green.
Start HS add node.
Add Node started...
Activate the 'Add to Network' function on the device...
A new node is being added...
Error - Add Node Failed reported by controller - you may try again. A "Restart" has been done on your controller.
I also factory reset the dimmer but still no luck.
any thoughts?
Start HS add node.
Add Node started...
any thoughts?
