I'm running the latest beta zwave and current HS4. Windows 10. I had been fairly stable for quite a while. I tried adding a new gen 700 Schlege lock and had lots of issues getting it to add at all. It seems to have caused all kinds of issues. I have now backed down to a config from 3 days ago saved as a backup before I added the lock. It seems to respond again after a reboot, but within 30 minutes stops responding. I have node in my database now for sigma devices that I can't even delete. For instance, Alexa gets slow and slow in response to say turn off a light, and then finally after a while there is no response...same from the browsers.
ANY suggestion for figuring out which piece is broken would be greatly appreciated!!!
I expected backing down to an older config would fix this...which is one reason I suspect an interface issue?
I'm just getting started troubleshooting but think it's only 1 of my 4 interfaces. It seems like everything on my other three interfaces other than the one I added the lock to "may" be OK. Sadly, most of my newer device like HS 200 and 300 interfaces are on that interface.
