I have used Alexa for voice control for years, and generally its been working very well. For the last 2 weeks or so, it has been extremely unreliable. I have a lot of routines set up, with custom answers from Alexa. So as a example I say turn on TV, and she responds turning on TV. Whats happening now in 50% of the time, she says turning on TV, but nothing else happens. I have tried running the routine from the Alexa app (pressing play), with the same result. When I try a minute later, she might do it.
This is with any voice command (routine). If I trigger the event (or change the device state) via HS4, it works instantly. I have checked in HS4, and I can see from the time stamp of events (or device) in question, that they do not run. So it seems to me, as this is a Alexa problem, not HS4.
Given that Amazon is reducing Alexa resources, it might have to do with that, so wondering if others are also experienced issues.
Is there any point trying to switch to google ? Another option is expanding Alexa voice control via Node Red. I do not have much in terms of Node Red voice control yet, so not sure if there are / will be issues too. I will probably set up more Node Red voice commands for testing anyway.
