Being in Canada, I do not have a zip code. Saying that, I still run HS3 and use Jeff's great WeatherXML plugin. I also have one HSTouch client which displays weather information including a 5 day forecast located centrally which we always look at.The weather infomation is provided by Darksky and with Jeff's image replacement, I have changing images for the current day (large) and the next 4 days including temps forecasted for the given day. As the API for Darksky is ending at the end of this month, I'm looking for a replacement which I would implement when I finally migrate to HS4 in April. (yes, I'm a very late adopter, but it has served me well in the almost 20 years that I am approaching with Homeseer). If I could keep Jeff's plugin, I would but I know there's no chance of an API addition or change being added anymore.
Back to the issue of zip codes, weather access is provided as a default to any HSTouch project by Homeseer, but this is of no use in Canada where we don't have zip codes, but, rather have postal codes. Will I lose this ability now going forward or can someone recommend an HS4 pluging which would work as a replacement which can provide images and forecast for HSTouch?
NOAA is U.S. only unfortunately.
Thanks in advance.
Robert
Thanks in advance.
Robert
