I've been a HomeSeer user for over 20 years (!!) but until now have used it largely for what I called "icing" - meaning the stuff that was nice to have, or gee-whiz, but if it didn't work all of the core stuff (the "cake") would carry on...
My cake has disappeared: I was heavily invested into the OmniPro II ecosystem, and well, we know how that ends.
I was/am loosely trying to replace the core security functions with an Elk M1; however, I'm finding so many gaps everywhere I turn that I'm now not so sure what is the best path to emplace the HS4 as the core of my security and home automation systems. Here's where I am today:
All of which brings me to: if I have to go through this pain and start with a blank sheet of paper - AND (I'm being greedy here, I know) want to have a system that is sustainable for at least the next 10-15 years - what should I start with?
#1-3 are the primary drivers and the rest is (relatively) "icing" so all that context provided and if I were to boil this into a single question it is:
What would be the best solution for heavy hardwired IO to interact quickly with HS4 to control lighting?
I'd be very grateful for thoughts/inputs/suggestions, thank you!
- 99% of my automation is driven by hardwired 1-pulse PIRs to track occupancy, movement, and direction.
- The Elk M1 has abundant IO, so good there - the question is, how to get it quickly into HS4 to act upon?
- About 15% of my connectivity is via an outbuilding separate from the house.
- Again, the Elk M1 can handle this from an expander/bus standpoint, so good. Same general handshake issue as above, but less timing critical.
- All of my lighting (about 70 loads) are Z-wave... and as noted in #1, the hardwired PIRs are the trigger for 99% of my automation, so I need something FAST from an IO standpoint and then to send out via Z-wave (or something; see Groups below).
- Given the UltraJones M1 plug-in is no longer supported, this seems a dead path. The question is: how do I get the Elk M1 panel and HS4 to talk to each other quickly?
- I understand the Elk M1 supports RadioRA natively, so that is a path but it comes at around a $7,000 cost to replace all my Z-wave hardware.
- (See above regarding response time criticality.)
- My window shades are Somfy RTS via the URTSII interface with the OPII. Have never been reliable, so I am faced with replacing all my window shades with either manual shades, or Z-wave. Another $6,000.
- My whole-house audio was the HAI HiFi 2, which now needs to be replaced with ??? Russound? Another +$5,000
- But then like the UltraJones M1 pluging, the BL Russound plugin also seems to not be currently supported in HS4?
- I have iPads in each room running Myro:Home as a GUI to the OPII - so in other words these are the primary UIs
- HS4/HSTouch seems to be able to reuse these, which is good (essential, given the investment)!
- Etcetera...
