Greetings all,
I have a question about limitations of receivers, buffers, and the HomeSeer scripting objects, AND I'm seeking advice on options for processing a high number of x10 incoming commands coming in in a series of short bursts.
I have been using x10 for home automation and scripting using HomeSeer's vba objects for 2-3 years. I just found this message board, and this is my first post. If I am posting this in the wrong place, please let me know... and/or cross post to the right place for me.
I am about to experiment with an application that would involve using a W800RF32 receiver (can receive x10 via RF for all housecodes, connects directly to computer rather than use power line signal) and up to 64 rf devices sending it signals - simultaneously.
Before I begin, I thought I would ask if anyone knows of limitations that I should be aware of regarding limits on the capacity of an x10 receiver to detect and buffer a high number of signals in a short amount of time.
A preliminary test indicates that going from a single generic (one house code, 8 device) RF remote to a generic (one house code) RF receiver, over the power line to a transceiver connected to my serial port, Homeseer starts dropping commands when I press the buttons faster than one press per approx. 0.5 seconds.
Because the test uses a single remote and the power line, I still intend to test the W800RF32 with 8 keychain/credit card (KR22A) type remotes to see what happens - then increment to 16 and 32 to test before going to 64.
I am most interested in information regarding the question above (limitations on receiving multiple signals from multiple sources in a short amount of time) AND in the best way to process the x10 commands as the come in. Because there isn't a unique tag to x10 commands as they come in, it seems that the LastX10 (which seems to use a "last in, first out" approach) method may not work for my purposes. What options would you suggest I explore? For example, is there anyway to programmatically traverse and read the HomeSeer log?
Any help would be greatly appreciated.
Best regards,
Mark Bolgiano
X10 Mad Scientist
Best regards,
Mark Bolgiano
X10 Mad Scientist
