2 audio zones
    2 audio zones
    Would it be an option for 2 audio zones (upstairs, downstairs, both) by using the left and right signals and controlling by using a script to change the balance on the PC ??
    Why not use 2 sound cards and switch between them?
    -Rupp
    What hair color do they put on the driver's licenses of bald men?
      just wondering if you could do something like this.
      I will probably pick up a couple of cheap USB sound devices....
        Are you certain that multiple USB sound output devices are supported by the OS?
          -- I'll troll around and figure that out first!
            ..... http://ubb.homeseer.com/6/ubb.x?a=tp...4&m=9096069884
            -Rupp
              I picked up a Creative USB soundcard last weekend and it sounds great! I love it because it has nice RCA inputs and outputs.
                hs.SetVolume 20,20
                By adjusting the two 20 values I think will play with volume and balance.
                HS 1.6.175 HSP 1.0.73
                Pentium 4 2.6 GHz w/ HT
                512 MB Dual Write RAM
                3 Fujitsu 510 Touch Pads
                Way2Call Hi-Phone USB
                NeoSpeech Kate 16
                Ocelot / SECU-16 / SECU-16I
                mcs Temperature (Works great!)
                NetCallerID Box
                ~Bill
                  You could do that, but I would think it could get difficult to keep track of where the balance/volume was set last. The voice output of HomeSeer is mono, so you could use the left and right channels as separate zones.
                  You can also get an inexpensive relay from Radio Shack connected to an X-10 universal module (or is it the PowerFlash? I always get those two mixed up) and since relays have normally open and normally closed positions, you could set it up where one or the other are always on, but not both at the same time. Two relays and two modules though would give you the most flexibility and then you would not have to worry about the volume level settings.
                  Regards,
                  Rick Tinker
                  HomeSeer Technologies
                  Regards,
                  Rick Tinker (a.k.a. "Tink")
                    Rick,
                    powerflash = contact monitor
                    universal module = control contacts/relays
                    Hope that helps
                    http://www.CocoonTech.com
                    HSPRO 2.4 (ESXi 4.1) | my.Alert NEW | my.Trigger | HSTouch | ACRF2 | UltraM1G | BLWeather | BLLan | Rover
                    (aka xplosiv)
                    Do You Cocoon? Home Automation News, Tutorials, Reviews, Forums & Chat
                      It does help at the moment, but with my feeble brain it is only a matter of time before I confuse them again... The problem is that I immediately moved into digital I/O controllers and never did use these devices much. Thanks.
                      Rick Tinker
                      Regards,
                        -Rupp
