Tonight I was attempting to get my Lightolier Fan Switch to work on the low setting. Martin suggested I try using a palm pad remote to see if that would work and sure enough it did. Now I need to understand why. The following are the codes from the ah.log when using the remote:
These worked:
<pre class="ip-ubbcode-code-pre">
3/24/2004 9:52:04 PM~!~X10 Received~!~C1(LRFAN) C Bright 12
3/24/2004 9:52:05 PM~!~X10 Received~!~ C Bright 1
3/24/2004 9:52:11 PM~!~X10 Received~!~C (LRFAN) C Bright 12
3/24/2004 9:52:12 PM~!~X10 Received~!~ C Bright 1
3/24/2004 9:52:15 PM~!~X10 Received~!~C1 (LRFAN) C Bright 12
3/24/2004 9:52:16 PM~!~X10 Received~!~ C Bright 1
3/24/2004 9:52:18 PM~!~X10 Received~!~C1 (LRFAN) C Dim 12
3/24/2004 9:52:19 PM~!~X10 Received~!~ C Dim 1
3/24/2004 9:52:21 PM~!~X10 Received~!~C1 (LRFAN) C Dim 12
3/24/2004 9:52:22 PM~!~X10 Received~!~ C Dim 1
3/24/2004 9:52:25 PM~!~X10 Received~!~C1 (LRFAN) C Dim 12
3/24/2004 9:52:25 PM~!~X10 Received~!~ C Dim 1
</pre>
These are the codes generated when using the dim command from the HomeSeer GUI. The dim to 50% and 100% (on) work. The dim to 10% does not.
3/24/2004 9:59:07 PM~!~Device control from menu~!~C1 Bright 10%
3/24/2004 9:59:15 PM~!~Device control from menu~!~C1 Bright 50%
3/24/2004 9:59:21 PM~!~Device control from menu~!~C1 Bright 100%
</pre>
As I have previously stated 50% works and 100% works
but the 10% doesn't.
Why are the commands different when sent from the remote and from the gui? Greg
These worked:
</pre>
</pre>
