This is a little off topic but I know there are some smart people here that might have come in contact with this.
I just bought a laptop which came with a internal wireless card. I have a LinkSys wireless router and I have a linksys 16 port hub. I have my main HS PC which is hard wired to the router using CAT5 connected into the hub. I can connect to the wireless router with the laptop with no problems and surf the internet. This works fine.
The problem I am having is that I tried to map a network drive on the laptop to a shared directory on my HS desktop PC and it will not map it. It causes the laptop to hang and then I must reboot. I am running Windows XP Pro on both the desktop and the laptop. I have setup 128 bit SSID on the router and like I said the laptop gets a connection right away with no problems, except that I cannot map a network drive from my other PC. It looks like it is going to map it (brings up a new window and everything, but then it just hangs). I did have it map the network drive correctly once, but it took 3-5 minutes to map it. I must be doing something wrong.
Has anyone had trouble with mapping network drives using a wireless router?
