i have a keypadlinc v2 and i would like to set up 2 of the non-load buttons so that one sends an a12 on and the other sends an a12 of - both of them in non-toggle mode.
the directions say to press and hold the button for 10 seconds then release and press for 5 seconds and then release and press again for 5 seconds again. this works but when i am finished the button remains lit and only sends the a12 on. i tried starting the press and hold process with the button lit and with it not lit and either way it ends up lit and sending an on.
also in the directions it says the following which i dont really understand - can some one explain?
"For example, if you want a button to always send the OFF command, press and hold 3 times as described above and then link it to another controller or button and send the non toggle button an off command (then unlink it from the button or controller)."
