In a wiring closet you connect your incoming cable to your cable modem, you connect your router to you modem and then you can connect PCs to the router. Can you simply take one of the router "out" cables and tie this into a punch down block and then connect more cables from this? My gut feeling is no and this is why they make switches and hubs.
If not then how is a part like this used?
