help sending a "CR" to a com port
  • Barry Gordon
    vb script should recognize the defined constants vbCR, vbLF, and vbCRLF with the obvious meanings
  • Rupp
    Carriage Return is & chr(13)
    Line Feed is & chr(10)
  • zoomkat
    You probably would use something like m & m & chr(13).
  • Guest's Avatar
    Guest replied
    Not sure but \n
    That is the standard CR escape sequence.
  • collegeboyslive
    started a topic help sending a "CR" to a com port
    using the hs.sendtocomport command how do i send some chartures then an "enter" or "CR" keystroke
    i need to send mm then an enter
    thanks
