Anybody have any experience with them? Do they cause powerline interference like CFLs?
120V LED bulbs
Originally posted by DC View PostAnybody have any experience with them? Do they cause powerline interference like CFLs?
If you are talking about 12v LED's, they cause no problem, except if you are using a dimmer watch the load, it's on the low side for most HA dimmers.sigpic
A founder member of "The HA Pioneer Group" otherwise known as the "Old farts club!"
I bought this one from eBay. It doesn't give off much light though. Nice for a night light is about all it's good for. Doesn't dim either. But for 5 bucks I just couldn't let it go!
I also bought a 90 LED PAR30 red spot light bulb from the same vendor. Now this is a nice light! Dims great and only uses 4.2w. I have it outside in my Halloween display.Bryan
Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
I'm talking about replacements for normal incandescent light bulbs. Like these:
http://www.smarthome.com/97314M/120-...ulb-VFL/p.aspx
http://www.smarthome.com/97314P/120-...ulb-V30/p.aspx
Originally posted by techno_goof View PostI also bought a 90 LED PAR30 red spot light bulb from the same vendor. Now this is a nice light! Dims great and only uses 4.2w. I have it outside in my Halloween display.
Originally posted by BrettS View PostHow bright is that one? Is it comparable to a 60W or so incandescent bulb? The price isn't bad at all.
I plan on getting 2 more for my Thanksgiving and then Christmas displays ... will help with the electric bill, that's for sure!Bryan
anogee
I use these bulbs from CREE.
http://www.1000bulbs.com/LED-Ceiling-Lights/
They are at least as bright as the bulbs they replace. I've replaced ever can in my house with these, and they work great, inside or out.
I've tried many others, but they are pretty much toy's compared to these guys. By the way, these bulbs are rated as 12W, but by my measurements, they use about 8W. They also dim very nicely, down to maybe 30%.
For $17 each I figured I might be able to get a few of the ebay bulbs to try out and see how they worked, but not if they're too dim.
::sigh:: Oh well... LED prices will go down and my budget will go up as time goes on... eventually they'll meet
Brett
anogee
Yeah, not cheap, but they should last 20 years, and pay for themselves in that time, many times over. I have about 25 can lights, and with CFL's I probably had at least one burn out per month. It was a pain after a while, as I have pretty high ceilings. Even worse, when it was colder, it would take them several minutes to warmup before they got to full brightness.
When people look at the cost of something, they just look at the purchase price, and I think that is very shortsighted. If your planning on being in your house more than 3 or 4 years, and you use the light several hours a day like we do, it is definitely the cheapest solution when compared to incandescents or CFL.
Here are some examples of this light in use:
http://www.creells.com/demos.htm
Anogee - Which bulb did you use from this page? I get confused at the different listings .... http://www.1000bulbs.com/LED-Ceiling-Lights/
anogee
There are two color temps and two types of bases. I use LLF-LR6 which is the standard base, 2700K, which is typical incandescent color temp. 3500K is sunlight color, but slightly blueish compared to incandescent. I think the other base is required for high-efficency bulbs required in CA.
No doubt, they will get cheaper like LCD TVs, and just about everything electric, but at the same time, your also not getting the benefit of having them. Each one saves me about $13-$15/year in electricity, actually even more when you consider my peak elec. charges at certain times of day, plus there is that 700w of heat my AC doesn't need to cool.
Originally posted by anogee View PostThere are two color temps and two types of bases. I use LLF-LR6 which is the standard base, 2700K, which is typical incandescent color temp. 3500K is sunlight color, but slightly blueish compared to incandescent. I think the other base is required for high-efficency bulbs required in CA.
My guess is that as they become more popular, the price will go down.
Agreed, watch out for color! 3500K usually considered warm white in florescent lamps.
I bought 5 under-counter LED lights for the kitchen. I'm not sure of the color, 5000K ?, but the light was awful. Turned everything grey. I went to xenon halogen lights for a much warmer tone. So 5 rather expensive lights now in a box in the basement
Paul
