I recently had a floodlight burn out so I went to the store and found a 90w replacement with 9 yr lifetime and 67w usage. It is way brighter than the old one. I has a curling fluorescent buld inside the traditional cone shaped floodlight casing. I like dit so much I went and bought three more to replace both sets of floodlights, front and back.
Just one problem: the lights don't respond to X10 signals from the handle remote of the HomeSeer program. They do work if you hold the button in on the light switch module. I have tried repeating the On command several times to no avail.
Any ideas, suggestions, solutions? Total cost so far < $50 for the lights. Are there other X10 light switches that can activate the lights or do I just need to get standard floodlights? Thanks in advance
