I want to plug in my home theatre power strip to an appliance module so I can shut down during non-use times... its not used every day, and there is a lcd tv, dvd, sat box, audio amp and a subwoofer... what is best module to use? i run HS with x10 (or insteon) and zwave. suggestions?
which best appliance module?
If you want an appliance module I like the ZRP100 it is the only module at this point that has a pass-thru so you don't lose the outlet. Another option is to put a controlled receptacle in - there are the HA01C, ZRR150 and the CA3500 in the Z-Wave Realm - HA01C and ZRR150 are top-controlled and the CA3500 is bottom-controlled.
Make sure you get a module that is rated for the load you are controlling. all that stuff probably draws over 5 amps. Something like the smarthome 2456S3 which can handle 15 amps should work just fine.
let me ask a question, are you sure cutting power to the devices isn't going to reset them back to factory defaults?
and when you cut the module back on, you are going to have a long startup time for everything to reboot (sat box especially)Mark
HS3 Pro 4.2.19.5
The VCR and tv may lose their time. The sub and amp should be fine.
You may want to get a kilowatt meter to see how much all the devices draw before going down the app module route.Mark
HS3 Pro 4.2.19.5
I kill my 'non essentials' (HS Server, Router/Switch, Cable Modem are the only things left on 24x7) when i'm not using them, the TV, Cable Box, Amp, DVD Player, Media Centre PC and XBox (which uses 20Kwh a year in standby alone) for me all added up to between 50-60w an hour when not in use, whilst it won't put a power station out of business, if I don't use them for 24hrs I save 1.2KW which all adds up when the bill comes...I use an X10 WS10 but it's unique to the UK - I would imagine any X10 appliance module, as long as its rated for the total current would be up to the job.
