Hi all!! My name is Jose and I would like to ask for some advice/ideas for my new project. I work for a spanish research center and I was asked to design a system to control the use of different kind of equipment which are quite heterogeneus btw (freezers, centrifuges, plate readers, distillated water systems...) that are being shared by all the scientists. The problem is that they want to know who is using the equipment and how much time.
I have thought about it and I have an idea about how it should be the system. The user should enter into the shared equipment room, go to the touch screen where the user will see the room schema/picture and touch on the device the user want to use. Then the user is validated using a fingerprinting device, card, username/password (still thinking about the options). For this step I will need scripting if I finally use hs to connect to the DB and check the user. Once it is validated, hs will let use the device to the user. I have thought about installing electromagnetic locks on the equpment because I can use it in the 90% of the devices. There are X10 multi relay controllers that could control the locks.There are other ones that depends on a computer or have an integrated computer with a rare operating system, but I am currently thinking about it. After the use of the device the user should go back to the touch screen and lock it. This is for be able to control how long the user has been using the device. Once I have the idea I need some advice to know which components are more suitable for my system because there are huge amount of them out there.
Thank you in advances guys!
