Powerlinc stopped working*** Fixed ***
    SH1132CU PowerLinc USB X10 Controller
    It has work great for 2 months now in my new house and today the power went off during the day....something to do with the 14" of rain in 3 days and more on the way. I came home and reset the computers and all the other parts and it won't do anything. I even installed another PowerBooster and still nothing.
    Computer log says it's working. I unplug it and replug it and get this:
    5/20/2009 6:07:45 PM Warning Powerlinc USB connection lost, resetting
    5/20/2009 6:07:45 PM Info PowerLinc USB Plug-in, Version 1.0.13
    5/20/2009 6:07:45 PM Startup PowerLinc USB initialized successfully
    Every command I send is logged in HomeSeer too.
    Any ideas? I hate to order a new one for 100 bucks if it's just a reset issue somewhere I'm missing.
    This device is good when it works but I've been through 3 of them in a year and a half. I finally ordered a TI-103.
      Not sure if related but I can't log onto HomeSeer from my other computer either....my router should effect the PowerLinc? I rebooted the whole system computer and all....still acting the same.
      Does the TI-103 come in USB? I'll have to get another Serial Interface-Converter if I use that one.
        Ok...I dug out an old CM11A and changed the port on the serial to usb converter and guess what? It works. So I guess my options are to add another serial to usb converter and use the CM11A or order a new USB Powerlinc of some kind. How does the dual X10/Insteon work? I don't have any Insteon...so maybe this will be the start?
          The 2414U are notoriously lousy both at receiving and sending X10 signals.
            So you would just get another Serial to USB converter and use either my CM11A or a T1103? Any of the others any good? Esp USB ones?
            CM11, CM12, CM15, CM17, TI103/213, Powerlink 1132
            What are the issues with it? Inconsistancy?
              I would only go with a TI-103 if you want a trouble free interface but it will require another serial port
              Yes. It sends a very weak X10 signal
                I ordered the TI103 and will pick up a Serial to USB converter today.....thanks for the help.....
                  Make sure it's a quality converter or you may encounter issues. This one has been tested and works well with the TI-103
                  http://store.homeseer.com/store/Converters-C179.aspx
                  http://store.homeseer.com/store/X10-C45.aspx
                    The 1132CU seems to be succeptable to power line blips. We had lightning storm a few weeks ago, and the 1132CU quit working after that. The green LED won't even come on, so I assume it's dead. I think I'm going to follow Rupp's advice and get a TI103 since I've been fighting with a CM15A and can't seem to get it working correctly.
                      Got my TI103 installed today...with generic usb to serial connector.....but it's reacting slow....not sure if it's the TI103 or the ACRF? Before when the ACRF was connected to the Belkin converter, it worked fine. Wondering if the new converter is the issue or the TI103?
                      I had the TI103 on com 1 and the ACFR on Com 4.
                      Ideas?
                      Another question....if you have a (2 Serial adapter) USB (one plug) and 2 serial plugs...how do you assign the com ports? I was thinking that the adapter would be one com port....not two? TI103 and ACRF on same port?
                      http://www.buy.com/prod/iogear-guc23...208370482.html
                        I just got my TI103, but I connected it through a HS2012 USB to 2 serial port adapter. Go to CONTROL PANEL ---> DEVICE MANAGER ---> LPT & COM PORTS. You should see two entries for your new adapter. The USB manager assigns the COM PORTS. My two showed up as COM7 and COM8.
                          How is it's response time? Quick?
                            Ok....I got a USB To 2-PORT Serial Rohs today....works great....so much faster response than the single line USB to Serial.....
                              But....now I'm getting the below....anyone have a clue what it means? Working fine just getting the mumbo jumbo on the log....
                              6/8/2009 9:20:00 PM Debug TI103 Dequeue: $>28001D03D03 CB#
                              6/8/2009 9:20:00 PM Debug TI103 Dequeue: adr
                              6/8/2009 9:20:00 PM Debug TI103 Dequeue: $>28001DONDON 3F#
                              6/8/2009 9:20:00 PM Debug TI103 Dequeue: cmd2
                              6/8/2009 9:20:00 PM Debug TI103 $<2800! D03D03 DONBA#
                              6/8/2009 9:20:01 PM Debug TI103 $<2800!DON2C#
                              6/8/2009 9:20:13 PM Info Command sent to Master Bedroom Ceiling Fan: E1 Off Dimval: 0 Data: 0
                              6/8/2009 9:20:13 PM Debug TI103 Dequeue: $>28001E01E01 C9#
                              6/8/2009 9:20:13 PM X10 Received E1 ( Master Bedroom Ceiling Fan) E Off
                              6/8/2009 9:20:13 PM Info Event Trigger "Bedtime"
                              6/8/2009 9:20:13 PM Info Device: Master Bedroom Tall Lamp (C2+1+4+10+6+5+16+12) OFF
                              6/8/2009 9:20:13 PM Debug TI103 Dequeue: adr
                              6/8/2009 9:20:13 PM Debug TI103 Dequeue: $>28001EOFFEOFF BD#
                              6/8/2009 9:20:13 PM Debug TI103 Dequeue: cmd2
                              6/8/2009 9:20:13 PM Debug TI103 $<2800! E01E01B7#
                              6/8/2009 9:20:13 PM Debug TI103 $<2800! EOFFEOFFAB#
                              6/8/2009 9:20:14 PM Debug TI103 Dequeue: $>28001C02C02 C7#
                              6/8/2009 9:20:14 PM Debug TI103 Dequeue: adr
                              6/8/2009 9:20:14 PM Debug TI103 Dequeue: $>28001C01C01 C5#
                              6/8/2009 9:20:14 PM Debug TI103 $<2800! C02C02B5#
                              6/8/2009 9:20:14 PM Debug TI103 Dequeue: $>28001C04C04 CB#
                              6/8/2009 9:20:15 PM Debug TI103 Dequeue: adr
                              6/8/2009 9:20:15 PM Debug TI103 $<2800! C01C01B3#
                              6/8/2009 9:20:15 PM Debug TI103 Dequeue: $>28001C10C10 C5#
                              6/8/2009 9:20:15 PM Debug TI103 $<2800! C0412#
                              6/8/2009 9:20:15 PM Debug TI103 Dequeue: $>28001C06C06 CF#
                              6/8/2009 9:20:15 PM Debug TI103 $<2800!C04F2#
                              6/8/2009 9:20:15 PM Debug TI103 Dequeue: $>28001C05C05 CD#
                              6/8/2009 9:20:16 PM Debug TI103 $<2800! C10C10B3#
                              6/8/2009 9:20:16 PM Debug TI103 Dequeue: $>28001C16C16 D1#
                              6/8/2009 9:20:16 PM Debug TI103 Dequeue: adr
                              6/8/2009 9:20:16 PM Debug TI103 Dequeue: $>28001C12C12 C9#
                              6/8/2009 9:20:16 PM Debug TI103 $<2800! C06C06BD#
                              6/8/2009 9:20:16 PM Debug TI103 Dequeue: $>28001COFFCOFF B9#
                              6/8/2009 9:20:16 PM Debug TI103 Dequeue: cmd2
                              6/8/2009 9:20:16 PM Debug TI103 $<2800! C0513#
                              6/8/2009 9:20:17 PM Debug TI103 $<2800!C05 C16BD#
                              6/8/2009 9:20:17 PM Debug TI103 $<2800!C16F5#
                              6/8/2009 9:20:17 PM Debug TI103 $<2800! C12C12B7#
                              6/8/2009 9:20:18 PM Debug TI103 $<2800! COFF89#
                              6/8/2009 9:20:18 PM Debug TI103 $<2800!COFF69#
