Setting up a remote control
  • Guest's Avatar
    Guest replied
    Will do thanks now to work out how to make the button and associate a remote signal to it.
  • Wadenut
    No problem. I'd advise selecting "cannot retrigger for ... seconds" on those as a debounce. One or two seconds should do.
  • Guest's Avatar
    Guest replied
    Worked a charm, thank you very much. Now for lots of setting up
  • Guest's Avatar
    Guest replied
    Thank you, i will have a go
  • Wadenut
    I don't know how your devices are set up, but lets assume a button press on your remote sends an On or Off to Homeseer. Let's call your device XYZ.
    An event to send an IR command would look something like:
    Name: whatever you like
    Trigger: Device XYZ set to status ON (or OFF as the case may be).
    Action: Send Infrared: ABC_IR (where ABC_IR is your learned IR)
    No scripting required.
  • Guest's Avatar
    Guest replied
    Well thats me knackered then as i know nothing about scripting, looks like i need to start doing alot of reading on this now
  • Rupp
    You will have to use scripting. You can read about that here:
    http://board.homeseer.com/showthread.php?t=132134
  • Guest's Avatar
    Guest replied
    Ok i have set up an individual device for a ir command and even set up an extra device to make the event for it but cant work out how to get is to sent the signal other than going into the control and clicking in there. Could someone please give me a step by step in setting this up please. I have the USBUIRT to learn the codes with itf that makes any diference
    Thanks in advance
  • Guest's Avatar
    Guest replied
    Thats what i thought, oh well a lot longer than i thought but here i go
  • Rupp
    You need a button/gadget per code.
  • Guest's Avatar
    Guest started a topic Setting up a remote control
    Hi there, I have learnt all my ir codes for all my equipment and they appear to work when i go into control on my status page. The question i have is that i would like to set up the HStouch software so do i need to make a device for every individual code or is there a way to do this whilst they are all in the remote control device.???
    Thanks in advance
    Edd
