Any interest in wireless RGB LED strip lights with HomeSeer?
    Kevin,
    My kids really love the Winamp plugin you created for your plugin would it be possible to have it save the input data so that it can automatically connect instead of having to manually inter the config stuff every time, Also can more than one instance be running at a time?
    Cheers Ken
    HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
      here's pics using simple corner mould to hide leds
      Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
        Originally posted by kenrad View Post
        Kevin,
        Cheers Ken
        Ken , yes , I can modify the Winamp Plugin for support save the settings in INI. So that when you next time open the plug-in , will read the settings from INI , no need to enter it again.
        "More than one instance be running at a time" , is that mean stream the data to multi-controller when playing music in Winamp ?
        Thx
          Yeah the ability to stream to multiple controllers would be awesome.
          Sent from my EVO using Tapatalk
            and in orange.. HUE lighting overhead and over couch to match !
              Originally posted by Pete View Post
              Here only using a wired connection. Got it (December?) with no wireless card.
              If you have a spare wireless AP; it might be easier to use that to configure the Wireless pieces of the RGB controller instead of playing with your existing AP.
              Here are the instructions:
              I get the light, but can't find it in my router.. also can't get the windows program to start.. gotta love win 8.1
              off to load on my laptop to see if I can get to it...
                Very nice Geary!
                I have a little free network scanner; but I can't find it right now.
                That said if you have logging on your router; and its off turn it on.
                You will not see it come up on the network/router until you reset your home wireless SSID such that it matches the default SSID mentioned above. If you are doing this on a wireless laptop connection you will disconnect yourself if using the same home SSID. Try it using a wired desktop or laptop connection maybe. Look up a bit on the thread; I had to install something to get it to run; don't remember what it was.
                Curious Geary; post what you have done so far.
                Auto mator
                  here we go..
                  accessed controller with 10.10.100.254 at SF... w I-pad ( Safari )
                  connects..
                  get menu up
                  enter admin, admin - login
                  opens page menu
                  Select STA Mode
                  there is a data transfor mode = transparent ( not covered in instructions )
                  go to STA Interface
                  search for SSID ( SpecOps), find...
                  MAC = Optional
                  Security Mode WPA2PSK
                  Encryption = AES ?? ( TPIK ? )
                  pass phrase = inter key
                  apply
                  STATIC
                  IP 192.168.1.5
                  SUbnet 255.255.255.128
                  Gateway = 67.77.159.1
                  apply
                  mode selection STA
                  Apply
                  Devise Mgt
                  Restart
                  shows rebooting.... forever...
                  loss of link light
                  still shows on old SSID, not new..
                    changed mask to 255.255.255.0
                    type off off AES and try again
                    link light blinked
                    AND WE ARE THERE !!!
                    Thanks for helping me discover my boo boo ( mask )
                      Great news!
                      STATIC
                      IP 192.168.1.5
                      Subnet 255.255.255.128
                      Your gateway IP should be in the same subnet as your IP and typically there is a DNS entry. The DNS entry could be your gateway IP or another other DNS IP in internetlandia. The IP of 67.77.159.1 looks to be your internet address provided by your ISP (just a guess).
                      IE:
                      STATIC
                      IP 192.168.1.5
                      Subnet 255.255.255.0
                      Gateway = 192.168.1.1 (or whatever you have configured in your router)
                      DNS = 67.77.159.1 (or whatever you have configured as a DNS address in your router or utilized; IE: like 8.8.8.8 or whatever.
                      The SSID should be able to get changed to your residential SSID and I am guessing that it did otherwise you would not have been able to connect to the RGB controller with Homeseer.
                      Auto mator
                        Kevin, I may have a bad controller
                        no red output
                        strange, checked w/ voltmeter
                        when I select red only, I get voltage ( gnd ) on green as well wii check further
                        leds worked w/ their controller
                        ok, no load
                        when I select red, I get 12 on Red, 12 on Green, 7 on blu
                        when I select Blue grn =0 red = 0 blu =12
                        when I select green grn =112 , red = 12, bul = 0
                        log show correct info going to controller ??
                        Do you want me to open up and look for short ?
                          no red output
                          ok, no load
                          Did you try to test with another power supply ? You can look into the previous post , another user also report that only one color turn on. Finally it find a problem on the power supply.
                          Did your LED is common 12V + ?
                          Thx
                            Kevin,
                            Cheers Ken
                            Actually I am make another program , that is monitor the Windows's volume output , so what ever is iTune , Media Player or Winamp , also should work on it. Once have a beta version , will post in here.
                              That Would be awesome, I mostly use Itunes But started with Winamp just to use your plug in for it
                              Cheers Ken
                                Thx
                                yes, same leds as most here reported using.. led's work fine with their shipped controller and power supply, using that power supply
