My Z-Wave network has stopped working in HS3. I get the following error messages:
**FATAL**: Failed getting InterfaceStatus from Z-Wave - the interface was not found in the list of active interfaces.
Initializing plug-in(1): Z-Wave Instance::General error setting up environment in InitIO: Object reference not set to an instance of an object. at HSPI_ZWave.ZWDatabase.GetDBVersion(Boolean& InvalidDatabase) at HSPI_ZWave.Database_Utils.LoadConfig(String filename) at HSPI_ZWave.HSPI.InitIO(String port)
Z-Wave Error Database failed to open. File: C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave.db, Exception=attempt to write a readonly databaseattempt to write a readonly database
When I look at "properties" for the config and data folders, I see that all files are read-only. I tried to change these but they revert back to read-only. I do not know how to fix these issues. Can anyone give me a clue?
