Ok, I'm a noob here and am having difficulty setting up scenes.
I'm using Z-Wave Aeon stick (v.3.0.0.174) and HS3(v3.0.0.96). Lighting is Cooper Aspire (RF9540) with a 5 scene Cooper Scene Controller.
When I use the light whether local, touch, or i-device everything is fine and works as it should. When I change the condition of the light the status is correctly reported and everything correlates as it should. Note, I do not having polling turned on.
I installed the 5 scene controller and assigned button 1 to a scene that controls one light (let's say media room). When the scene is activated either by the controller or via event it works as it should. The light turns on and off accordingly.
The issue revolves using both together. Meaning when the light activates via scene the correct status is not updated FOR THAT LIGHT in the Device Mgmt. Also, if the switch is turned off locally it appears the Scene is still active on the controller.
How do you get the two to play nicely together? Do I need to program a bunch of events, poll, associations, etc. to get these to work and status correctly?
Thanks in advance for any enlightenment...
