HS3/BLRF/WG800USB X-10 Not "Heard"
Thanks for the suggestion Don! I changed the dropdown to "SerialPort" but still nothing. I then tried unplugging the W800 and plugging it back in again. Now life is good again, and X-10 RF signals are being heard, whether set on MSCommLib or SerialPort. Guess it just needed a hardware reset!
Originally posted by chewie View PostI have run into issues similar where the W800 seems to have up to a 10 second lag using BLRF that was not there in ACRF-2 on HS2. I will try resetting it and see if that helps, but my motion sensor activated events have been unusable since moving to HS3.
No, my RF systems for my W800 are totally hit or miss and I have more or less given up on them. If I restart the system pretty regularly it will work, but I honestly have not spent a tremendous amount of time troubleshooting it. For the most part the events associated with this are not the most important in my house so when the wife got annoyed we just assumed they would not work and moved on.
Originally posted by chewie View PostNo, my RF systems for my W800 are totally hit or miss and I have more or less given up on them. If I restart the system pretty regularly it will work, but I honestly have not spent a tremendous amount of time troubleshooting it. For the most part the events associated with this are not the most important in my house so when the wife got annoyed we just assumed they would not work and moved on.
As an FYI, I'm using the W800 with the RFXCom plugin as I already had it, and I see no lag at all with it. Also what version of HS3 are you running? There have been some bug fixes related to event performance and it might be worth trying .149.
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
