Intro
My home currently has an electric heating system (boiler, radiators and towel rail) which is controlled using a proprietary pilot wire bus arrangement which seems difficult to integrate with. I'm looking to achieve Homeseer Control of the system.
The current System
Each device is connected to a ring main.
Zones of devices (IE: Zone1 = upstairs radiators, Zone2 = Bathroom towel rail etc) are linked together with a single core control cable which runs at 240V 1mA. The heater output is either preset or adjustable locally on each device using a physical slider.
A control unit has multiple zone outputs and a configurable schedule. It is essentially very basic - turning the zones on or off based on the set schedule. However, it also has a "frost protection" mode which essentially sets each device to it's minimum output.
I'm in the UK and it's a system from a UK manufacturer. I can't find similar systems from any other suppliers so don't know if there is a US equivalent. The manufacturer offers minimal information (http://www.dimplex.co.uk/assets/kb/o...ns_Issue_4.pdf)
My Thoughts / Questions
- The pilot wire doesn't seem to change voltage when the controller is in different modes so I presume there's a frequency change in the voltage. How can I check this with basic tools / knowledge
- Is there any interface on sale that may work with this system
- Am I better off just fitting a z-wave relay to each heater and disconnecting the current system? (obviously adding temperature sensors to the rooms)
Thanks for your thoughts in advance.
The current System
