Monoprice temp/motion sensor not working below freezing
    Any idea why the sensor would stop reporting temp as soon as it hits 32f? Says status unknown in home page and reports 32 still as a value. Its in my garage which is probably around 25f right now.
    Here is the error i'm seeing.
      I have no idea on that error as I have not used the monoprice items, but how are they working for you overall? This error aside I mean.
        They work well. I don't have any other sensors to compare them with though. But motion events work flawlessly.
          25f is within the device's operating range so it could be a software issue. Maybe the code is not configured to handle temp data of freezing or below even though it's receiving/reading the value (32f) ok? Do you have any other temp devices you can use to test? Maybe other folks here with similar temperatures can comment on their experiences...
          All Z-Wave, #101 devices, HomeTroller Series2, HomeSeer2 v.2.5.0.81, & 1x Z-Troller
            http://bugzilla.homeseer.com/bugzill...ug.cgi?id=2539
            Submitted to bugzilla.
              Seems like a great price on these!
              Are these motions working well still? Any resolution on freezing bug?
              http://www.monoprice.com/product?c_i...=151101_sunday
                Looks like this bug still exists. I recently switched from Vera and it reported the temp correctly. I just updated the Bugzilla log since it doesn't look like anything was ever done.
                To recap, once the temperature drops below 32 deg, homeseer displays random large numbers (usually between 200 and 500 deg F). I've tested two monoprices sensors and one GoControl sensor (which are all the same hardware). Hopefully they fix it.
                Also my log is only showing the following Zwave warning: Exception processing received application frame for encapsulation: Number overflow.
