How does the HS2/HS3 import utility function?
Does this help: http://board.homeseer.com/showthread.php?t=163318?
I manually migrated from HS2 to HS3. Most plugins will create their own devices, so you really can't import them and the event engine works differently so events all need to be redone. I did it slowly over a few months, migrating one plugin at a time. HS2 and HS3 can run at the same time (on the same or different systems) as long as they don't access the same hardware interface.
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Yeah, I tired the import utility and there was so much missing, and some node issues, that I ended up doing a complete new install of software and z wave device( delete then Add). Have to say it was worth it though, because hs3 is a lot easier to use than hs2 was. For me hs3 also has been much less( almost none) buggy.
TomTom
baby steps...starting again with HS3
HS3Pro: Z-NET & 80 Z wave Devices,
HSTouch: 4 Joggler (Android Kitkat), 2 iPhone, 3 iPads
Whole House Audio: 5 SqueezePlay Jogglers w Bose Speakers
In The Works: 10 Cameras Geovision, new Adecmo/Envisalink Alarm, Arduinos
System: XP on Fanless Mini-ITX w/ SSD
Originally posted by GSATWO View PostThanks guys! Well, that's disappointing 😱! So, what was the point of the import utility? Thanks again.😰
