I'm having difficulty in adding the Trane TL624 to HS2 - likely due to my lack of experience with Z-wave. Go gently on me
So it seemed to have added but perhaps not completely..
I see the device on the devices page but no controls and it's reading the wrong temp. I optimized my network and it appears fine.
Do I need to associate it with HomeSeer? Still not overly clear on the association part of z-wave...
24/03/2016 2:28:08 PM Z-Wave Instructing node # 10,Z-Wave Interface Z-Wave Thermostat 10, to re-discover its neighbors using the MAIN Z-Wave interface...
24/03/2016 2:28:08 PM Z-Wave Optimization of node 10 successfully started...
24/03/2016 2:28:27 PM Z-Wave Device 10, Z-Wave Interface Z-Wave Thermostat 10 successfully optimized.
24/03/2016 2:28:31 PM Z-Wave Removing and Adding Return Routes for Device 10, Z-Wave Interface Z-Wave Thermostat 10...
24/03/2016 2:28:37 PM Z-Wave Removing and Adding Return Routes for Device 10, Z-Wave Interface Z-Wave Thermostat 10: Result=Successful
24/03/2016 2:28:37 PM Z-Wave Device Z-Wave Interface Z-Wave Thermostat 10 Optimization and Add Route completed successfully.
24/03/2016 2:28:50 PM Device Update Device: Z-Wave Interface Laundry ZSmoke Alarm Status set to ON
24/03/2016 2:28:57 PM Event Event Trigger "Sump Pump Off"
24/03/2016 2:28:57 PM Event Running script in background: SumpPumpOff.vb
24/03/2016 2:30:15 PM Z-Wave Return route queued to be added from node 9 to 1
24/03/2016 2:30:28 PM Z-Wave Return route queued to be added from node 9 to 10
I first tried to add it by bringing my Ztroller to it and pressing the add button while I enabled the enrollment on the stat. That didn't seem to work, so I just selected add node in Manage Zwave on HS2 while enabling the enrollment on the stat.
So this is where I am... Any/all experienced Zwave stat guys comments welcomed...
Robert
EDIT: Getting a few devices but a number unknown and this in the log.
24/03/2016 2:54:16 PM Device Update Device: Z-Wave Interface Z-Wave Thermostat 10 Temperature value set to 69 (6900/F)
24/03/2016 2:54:17 PM Warning Z-Wave Multilevel Sensor device Z-Wave Interface Z-Wave Thermostat 10 Multilevel Sensor Unknown is missing Sensor Type information - cannot update sensor status.
Robert
