Eman - That is brilliant - thank you. I'll have a look at that this weekend; hopefully, I'll manage to build something.
Cheers
Scott
control Velux skylights with HS3 and RFXCOM?
Originally posted by ScottRennie View PostCheers Eman - that looks interesting. Where can I find detailed instructions on how to install and set up MQTT? There is a lot of threads but not a lot of information.
ioBroker has a Node-RED node as illustrated here #10 by which makes it super cool to send data to mqtt.
Note : If you are just starting with mqtt, let stuff communicate locally with user name and password. Anything else is beyond the scope of this post and / or do some research.
Eman.
I would like to know as well. Any feedback on the KLF200 would be appreciated
https://flows.nodered.org/node/node-red-contrib-velux then use the MQTT plugins in HomeSeer to talk to them.
Eman.
Originally posted by jameseoconnor View PostHorse,
Any luck in controlling your Velux products via HS3? I am looking at buying some Velux skywindows and would like to control them via HS3. What worked for you?
Horse,
I know this is a very old thread, however I came across an announcement that Velux have released an API for the KLF 200 io-homecontrol gateway
The klf-200 allows "dry contact" , web and now an API control of io-homecontrol enabled Velux windows and blinds, in addition others have successfully registered Somfy products as well as they use the same io-homecontrol protocol.
I'm including a link to the Velux page for the API which seems to be very well documented and supported (111 pages). Just not very well advertised :-)
Currently I'm going to be installing a number of Velux products in a new house and am using the Arduino plugin and a signal relay board to control the klf 200 via dry contact. A plugin to HS3 that uses this API over IP would allow for scenes and status.
I'm no coder, and am going to look into doing some simple Python scripts on a web server to do basic scenes, as I'm not sure were to start with the HS3 plugin framework. Are there any guides?
Last I heard Velux used "their own" IO Homecontrol protocol.
Regards
Morten
Originally posted by Ricky View PostAl, I found this old thread, probably concerning an earlier model. Does it change your thinking?
http://board.homeseer.com/showthread...ighlight=velux
Could you expand on why you mean "interfacing to the KLF100 using something that can provide dry contacts..." I'm not following you there. Just my limited knowledge...
Thanks, Ricky
Cheers
Al
Originally posted by sparkman View PostLooks like the Velux remotes are in the 2.4 gig band so the RFXCom transceivers won't be able to control in that case: https://fccid.net/number.php?fcc=XSG833429&id=708925. You should be able to interface to the KLF 100 using something that can provide dry contacts (Mimolite, Relay, Arduino, etc.).
Cheers
Al
Thanks, Ricky
I've got one of those skylights as well. I'm hoping to control it with my new neeo when I get it sometime this month...
Rob
Cheers
Al
I wonder if it is possible to control Velux skylights with HS3 and RFXCOM? Has anybody done this?
http://skylights.veluxusa.com/consum...ctric_controls
http://velux.skylightblindshop.com/b...t-klf-100.htmlTags: None
