This is my first post here on the Homeseer forum.
Im totally new and now have an working HS3 envoirement with some Visonic/Hue/Rfxcom devices. Also bought Imperihome and Jowihue plugin.
It all works but have to learn a lot and reading here a lot of posts.
Sorry if i post this in the wrong section but when i search for "Youless" i get zero hits.
The only thing that wont work ok is the following:
I have an Youless energymeter device which monitors my old energymeter.
On an Dutch (Domoticaforum) forum i found some info how to install this device:
Make 2 virtual devices and let them update every minute with an event.
This works, only problem i think is that there is coming no data in the Value field, only in the "String" field.
So when i want to log the data for example to use in Jon00 database or in Imperihome or in Device history, nothing will be logged.
Is there a solution and will somebody look in the attached script what is the problem?
(I had to change the file extension from .vb to .txt otherwise i could not upload the file)
