Hi all, I'm fairly new to Homeseer after moving from an ISY994. I'm have only one thing left I'm trying to do that I once did with the ISY. I've already received great help from the group and I'm sure someone here will have the answer I'm looking for.
I'd like to create an event (or events) that will turn on a device during set hours but only if one of several other devices is also already on. Basically I want to create a:
IF '1' is on AND ('2' is on OR '3' is on) THEN turn '4' On
In this example '1' is a virtual device created that turns on at a start time and turns off at the end time. Items '2' and '3' are the other devices, only one of them must be on in order for the 'THEN' commands to be sent.
The problem is that when I create the event, it seems to follow this:
IF ('1' is on AND '2' is on) OR '3' is on THEN turn '4' On
Is there a way to group the 'ORs' together? Maybe scripts are the way to go. If so, I'll have to learn how to use them. :-)
Thanks in advance,
Eric
Thanks in advance,
Eric
