I don't think the clear plastic has a significant impact on the readings; at least not for private/non professional usage.
I would not recommend exposing the sensors directly to the elements.
some more information if you want to reproduce my design:
- I used plastic tubing (12 pieces - same lenght - about 5/8 in) over the threaded rods as spacers between the "bowls"
- As seen in pictures 2-3-8 above, added aluminium (easier to close the ends) mosquito net from top to bottom in case bugs would be tempted to use the station as a hotel.
especially the top "penthouse" =)
- The BME 280 is located center - middle height, so that its sensors are well ventilated while being protected from elements.
Cheers,
Yann
Cheers,
Yann
