Howto change from US to UK/EU date format in HS3 linux/Pi
  • Howto change from US to UK/EU date format in HS3 linux/Pi
    How to change from US to UK/EU date format in HS3 linux/Pi
    By default HS3 displays dates in the US mm/dd/yy format. To change to the UK/EU format of dd/mm/yy make the following changes to your system.
    1 - Log in to your system command line using SSH from another linux box or an SSH client for windows such as Putty.
    2 - Ensure that the system locale is set to your region (in this example we will use en_GB for the UK).
    a. Check the current locale typing:
    localectl
    This is what I see on my laptop.
    ICS-HPN:~$ localectl
    System Locale: LANG=en_US.UTF-8
    VC Keymap: n/a
    X11 Layout: us
    X11 Model: pc105
    b. If the current locale is not correct, check that the required locale is installed:
    localectl list-locales
    en_GB.UTF-8
    c. Change the system locale to the desired region
    sudo localectl set-locale LC_ALL=en_GB.UTF-8
    d. Check the change has been implemented:
    localectl
    3 - That has changed the system locale to the correct region.
    However, HomeSeer changes the locale of the homeseer user to en_US, on the fly, when HomeSeer starts so it is necessary to edit some HomeSeer configuration files to complete the changes.
    By default linux comes with vi as its command line editor. Many find the interface difficult to use and prefer nano instead. To install nano, issue the following commands:
    sudo apt-get update
    sudo apt-get install nano
    a. Change the homeseer startup file:
    sudo nano /usr/local/HomeSeer/autostart_hs
    Change the line:
    export LANG=en_US.UTF-8
    to
    export LANG=en_GB.UTF-8
    b. Change the homeseer go file:
    sudo nano /usr/local/HomeSeer/go
    Change the line:
    to
    c. If necessary add you actual location to the location.csv file. To add your location edit the file:
    sudo nano /usr/local/HomeSeer/Config/location.csv
    and add your actual location copying the format of already entered locations. NOTE: there is a long standing feature/bug that the longitude values in the file are reverse signed. ie West of Greenwich values are positive instead of the expected negative.
    4 - Restart the system to implement the changes:
    sudo reboot
    Author - adeux - Mark
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.4X
    Homeseer Zee2 (Lite) - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.4X
