Updating Pine64 2Gb Ubuntu 16.04 64 bit to Ubuntu 18.04 64 bit
    1 - backed up HS3 to another computer running Ubuntu 18.04 64 bit - shut down Homeseer 3 on Pine64 2Gb computer
    2 - via command line:
    A -
    $ sudo apt update
    $ sudo apt upgrade
    $ sudo apt dist-upgrade
    $ sudo apt autoremove
    B -
    $ sudo apt install update-manager-core
    C -
    $ sudo do-release-upgrade -d
    Ubuntu will ask you a couple of questions about how you want to handle the upgrade, and it'll start off upgrading your system.
    Note: Writing this while attempting the upgrade. Not sure if it'll work yet.
    Last message from upgrade:
    Upgrade complete
    The upgrade has completed but there were errors during the upgrade
    process.
    Will reboot to see if it boots up using the microSD card.
    Worked and rebooted a few times updating Webmin and installing xRDP as this computer runs headless.
    Pine64:~# uname -a
    Linux ICS-Pine64 3.10.105-bsp-1.2-ayufan-77 #1 SMP PREEMPT Sun Jul 9 12:09:30 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
    Pine64:~# lsb_release -a
    LSB Version: core-9.20170808ubuntu1-noarch:security-9.20170808ubuntu1-noarch
    Distributor ID: Ubuntu
    Description: Ubuntu 18.04.1 LTS
    Release: 18.04
    Codename: bionic
    Pine64:~# mono -V
    Mono JIT compiler version 5.12.0.301 (tarball Wed Jul 25 16:57:14 UTC 2018)
    xRDP desktop for those interested.
    Disabled HS3 on transitional machine and enabled HS3 on Pine64 computer.
    Sunday July, 29. 2018 0737C
    Running HS3 fine at this time with update to Ubuntu 18.04
    - Pete
    Auto mator
    Fanless IntelĀ® Celeron N3160 SoC 8Gb
