I am doing this vivo on the console rather than remotely using SSH like I did for the Pine64 2Gb computer.
Previous to this have upgraded 3 laptops (16Gb) and desktop (32Gb) to Ubuntu 18.04 / Windows 10
IE: been running these now for over a month and they are doing well.
1 - shut down Oracle VB
2 - shut down Homeseer 3
3 - via terminal window
4 - sudo su
5 - sudo apt update && sudo apt dist-upgrade
HS3Pro:/home/pete# sudo apt update && sudo apt dist-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
6 - sudo apt install update-manager-core
update-manager-core is already the newest version (1:16.04.13).
7 - do-release-upgrade -d
First attempt was fast and full of errors. Probably because I was using VNC to access the desktop.
2nd attempt at update looks good so far. This was done on the desktop via a terminal session.
This computer was updated from Ubuntu 14.04 to Ubuntu 16.04 a couple of years ago.
Might purchase a new SSD (faster one) and install Ubuntu 18.04 on it replacing current SSD after this one is running.
HS3Pro:~# lsb_release -a
LSB Version: core-9.20170808ubuntu1-noarch:security-9.20170808ubuntu1-noarch
Distributor ID: Ubuntu
Description: Ubuntu 18.04.1 LTS
Release: 18.04
Codename: bionic
HS3Pro:~# uname -a
Linux ICS-HS3Pro 4.15.0-30-generic #32-Ubuntu SMP Thu Jul 26 17:42:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
mono -V
Mono JIT compiler version 5.14.0.177 (tarball Mon Aug 6 09:13:43 UTC 2018)
Desktop changes with Ubuntu 18.04 had to be fixed. Really it was only the network manager and I rarely use the desktop.
Homeseer 3 and Oracle Windows VB is working fine.
Had an issue with a slow boot and reboot. This is a documented bug in Ubuntu 18.04.
HS3Pro:~# systemd-analyze blame
20.803s plymouth-quit-wait.service
5.450s networking.service
5.215s stunnel4.service
2.497s webmin.service
1.261s dev-sda2.device
Still booting a bit slower than when running Ubuntu 16.04.
Here is the system boot on the Pine64 - which is a bit slow using the microSD
Pine64:~# systemd-analyze blame
52.776s fstrim.service
16.181s dev-mmcblk0p2.device
13.455s systemd-fsck-root.service
4 - sudo su
Release: 18.04
Codename: bionic
HS3Pro:~# uname -a
mono -V
