Contacting HomeSeer This Week
See more
See less
How to change value on a device valuecheck in an eventtrigger.
  • How to change value on a device valuecheck in an eventtrigger.
    Hello,
    Is it possible to change the temperature value in a trigger of an event in an automated way.
    I'd like to modify the temperature value (27°C) in the event trigger based on the measured outside temperature.
Name:	Event example.JPG
    Joris
    I think the only way to do that is with a script. You could have a script checking the out side temperature, and depending on temperature execute an action
    I am doing something similar with a script
      Originally posted by Joris Vandoren View Post
      Hello,
      Joris
      EasyTrigger would allow you to do it by setting the temperature value in a virtual device and then using the trigger "Comparison between 2 device values becomes true".
      -Wade
        "EasyTrigger would allow you to do it by setting the temperature value in a virtual device and then using the trigger "Comparison between 2 device values becomes true".
        I've implemented your suggestion, I'll monitor tomorrow the behavior of the sunblinds. This is exactly what I was looking for.
        Thanks."
          Glad I could help.
          -Wade
