Contacting HomeSeer This Week
See more
See less
sonos hs touch integration
  • sonos hs touch integration
    Hi All
    can anyone share some information about integrating Sonos to hs touch ?
    I would like to make a simple page with basic controls and window which shows what is playing now
    Checkout this thread, took him 187 events, bottom line he suggests just using the Sonos app. Since the Sonos plugin creates a device with child devices and controls you could do it but will need to add each element and control.
    https://forums.homeseer.com/forum/ho...ch-project-out
    EDIT: meant to say Sonos plugin not app: changed
      +1 on using the actual Sonos app. I just created a button that launches the app, and an event that causes HS to "push" that button (so I can initiate it from elsewhere, including Alexa). Since I use Android tablets, I have another event that sends a message to "Tasker" that will close the Sonos app, which will return the tablet screen to Touch (since it is still running).
        Has anyone successfully launched the Sonos app from an iOS client?
        Mark
        Hometroller S6 w/ HS3Pro, Way2Call
        BLAB8SS, BL Backup, Easy Trigger, HSTouch, Open Sprinkler, SONOS, Ultra1Wire3, UltraM1G, WeatherXML, Z-Wave
          that is a lot of work . I’ll try to do something similar but just very basic like some favorite playlists volume. Next song play pause That is what I’m missing most quick access without changing apps .
            That is good idea however may not work for me . I have iOS iPads and not sure if I can do that with them plus for some reason sometimes it takes some time for Hs touch to reconnect after I change app even without logging out or turning it off
            thanks for advice
              Originally posted by hazy View Post
              ........it takes some time for Hs touch to reconnect after I change app even without logging out or turning it off
              thanks for advice
              I get the same on Android and find it faster to kill and restart HStouch if it has been in the background for any length of time.
                I had difficulty running another app on Android at first due to the confusion brought by the Touch button action "Load Application" having a misleading "Path" parameter label. When running a windows app on a Windows Client, the file path and name of the executable would be specified here (i.e. something like "C:\Program Files\Sonos\Sonos.exe"). However on Android, no file path is specified, just the name or title of the program (i.e. just "Sonos" w/o quotes). I suspect that iOS is done the same way. Be sure to spell the program name exactly how iOS has it.
                  This was also happening to me as well. Then I assigned "fixed" IP addresses to the tablet (by using my router's IP Reservation feature), and the problem went away for me.
                    Interesting, fixed IP on the client, I'll give it a try.
