Trying to send the hs3 memory usage to a mqtt ( only hs3 process)
  • Trying to send the hs3 memory usage to a mqtt ( only hs3 process)
    So I created this file
    #!/bin/sh
    pids=$(pidof /usr/bin/mono /HomeSeer/HSConsole.exe); for p in ${pids[@]}; do cat /proc/$p/status | grep -i vmrss | awk '{print $2}'; done | while read m; do let t=$t+$m; echo $t; done | mosquitto_pub -h 127.0.0.1 -t Hs3/memory -m "$(tail -n 1)"
    the problem is that i get all the process run by mono ( all hs3). So it give me 1gb of memory used.
    when i replace the pidof with this :
    #!/bin/sh
    pids=$(pidof /usr/bin/mono /HomeSeer/HSConsole.exe --log); for p in ${pids[@]}; do cat /proc/$p/status | grep -i vmrss | awk '{print $2}'; done | while read m; do let t=$t+$m; echo $t; done | mosquitto_pub -h 127.0.0.1 -t Hs3/memory -m "$(tail -n 1)"
    I got an error that pidof do not recognise --log function.
    Maybe i have some error in the systaxe i posted here, but that is not important. the improtant thing is how to make '' /usr/bin/mono /HomeSeer/HSConsole.exe --log '' be recognized by pidoff ?
    thanks!!
    ok... i am getting near of the goal with this :
    #!/bin/sh
    while true
    do
    t=$( ps axo rss,cmd | grep '/usr/bin/mono /HomeSeer/HSConsole.exe --log' | grep -v grep)
    mosquitto_pub -h 127.0.0.1 -t HS3/MemUSED -m "$t"
     sleep 30
    done
    But not able to remove the ''cmd'' for only using :
    ps axo rss | grep '/usr/bin/mono /HomeSeer/HSConsole.exe --log' | grep -v grep
      To be more explicit here is a picture of output i get when I send the command with or without ''cmd'' to the terminal ( and without of course getting anything via mqtt).
      With
      I get : 187252 /usr/bin/mono /HomeSeer/HSConsole.exe --log
      With
      I get : Nothing
        ha.. i think Grep use the cmd attribute in a reverse manner to find the memory usage associated to it. So it is a little hard to remove ''cmd''
