Hello new to HS and it looks like it will replace my 14 year old home logic hgomebrick system. I have a Russound cav6.6, a upb lighting system and aprilaire 8810 thermostats. Is there a install guide for dummies that I can access to get everything set up. I am slowing getting acquainted with the new system, but there is so much to learn and i was looking for a quick short cut guide. Any help would be greatly appreciated. Thanks, Rick
New to Homeseer 101
Originally posted by rabjab12 View PostHello new to HS and it looks like it will replace my 14 year old home logic hgomebrick system. I have a Russound cav6.6, a upb lighting system and aprilaire 8810 thermostats. Is there a install guide for dummies that I can access to get everything set up. I am slowing getting acquainted with the new system, but there is so much to learn and i was looking for a quick short cut guide. Any help would be greatly appreciated. Thanks, Rick
software-plug-in
But to spare you the crap here goes :
Start here : https://www.homeseer.com/guides/Home...tart-Guide.pdf which I think you have already seen.
Then for all other documents : https://www.google.com/search?q=Home...hrome&ie=UTF-8
And to top it up, it's quicker to learn from videos so go here : https://www.youtube.com/HomeSeer
If you get stuck or your project is so custom then come back and ask.
Like for Russound : http://www.automatedhomeonline.com/H...oundaudio3.htm
Aprilaire 8810 thermostats : https://shop.homeseer.com/products/s...lug-in-for-hs3
Tip: It's best to mention one brand at a time because not everyone's system is set up the same and thus that way you're rooting for ideas.
Eman.The Closer.
Originally posted by rabjab12 View PostEman,
Thanks for the help. One question I thought of was, do I need a controller from Homeseer, or can I just run it from a small cpu. like the homebick did?
Eman.The Closer.
Originally posted by rabjab12 View PostJust watched the video. Do I need a z wave device? currently running everything through a pc. but outshout success of anything working.
Eman.The Closer.
I have a CAV 6.6 and use Blade's plug-in. Both plug-ins are worth considering. I'd suggest reading through some of the posts for both plug-ins to see if the tone of the discussion of either sets it apart. I also have UPB, and I definitely recommend Spud's plug-in.
HS3 Pro Edition 3.0.0.548
Originally posted by rabjab12 View PostThanks to all for the feedback. Considerinh building a small pc to run th ehomeseer, as my old homebrick got ransomware. do i go with a small pc or the troller?
Eman.The Closer.
