It it possible to adjust temperature/humidity offset in HomeSeer?
  • It it possible to adjust temperature/humidity offset in HomeSeer?
    I am new to HomeSeer and I am trying to get some of my devices switched over and create some events based on temperature and humidity. I am noticing that the temperature and humidity being reported by my Zooz 4-in-1 (ZSE40) sensors seems to be off. I looked through the documentation and there doesn't appear to be a parameter I can set to adjust this on the device itself. I was a previous SmartThings user and the device handler had the ability to offset the values. Is this something that is possible in HomeSeer?
    I adjusted the offset under the devices status tab but that doesn't appear to effect the value reported to the events.
    Currently I am compensating in the events but this is a bit hard to keep track off when I am testing. I have added a note to the device but it would be awesome if I could get the event to fire off based on a more accurate reading.
