How to operate serial relay board with HS3pro
  • #16
    I believe you need just a single connection and put COM3 in the address field. For the command, the quotations should be left out. You’ll have to play with the Type drop down to see what works.
    HS 3.0.0.532: 1963 Devices 1141 Events
    Z-Wave 3.0.1.261: 122 Nodes on one Z-Net
    • #17
      Thanks, I'm trying a these changes and will let you know if it comes up.
      • #18
        sparkman, I have spent many hours trying to make this work, after backing everything out, in order to start over, it appears that I didn't get all the old out. I went ahead and posted on the main thread for this program.
        • #19
          Just to update this thread, the ip-serial-plugin-for-hs3-by-drule suggested by sparkman appears to be a great plug in, I have it installed and it is opening the com port and sending data, just haven't figured out how to get it to send what the board wants to see. If I find a solution, I will update this thread for those coming after me.
