Help with Webrelay
  • Help with Webrelay
    From a browser I can type " http://10.0.1.119/state.xml?relay01=1 or 0 " into the address bar and change the state of my webrelay relay #1 on or off by changing the number after the = sign. Obvisouly the 10.0.1.119 is the IP address of the relay device. I have been trying to figure how to create an event that will do the same as me typing that into the browser. I want to control this IP based relay for many different functions on the network. I've tried sending a vb string and unless I don't know the proper syntax I cannot make it work. Any help here would be GREATLY appreciated.
    You can issue the following immediate script command from an event:
    &hs.GetURL("10.0.1.119","/state.xml?relay01=1",TRUE,80)
