Originally posted by Deadeye
View Post
Integrating a Security System with Homeseer?
Hi,
I use a Honeywell Vista Panel that was already installed in my house. I bought a piece of hardware “Ad2usb” for $99 and the plugin for Vista panels.
I am able to arm, disarm, turn on/off the Chime for doors, etc.
I also have Blue-iris and the plugin. I started doing events to notify me when the alarm is in a “armed state” and motion is detected outdoors... and honestly had to turn it off since I had way to many alerts for trees and leaves causing false alerts.
You can find vista 20p panels for nothing on ebay ($40-80).
The benefit of an alarm system is that sensors are hardwired and you dont rely on batteries.
Enjoy
Cheers
Originally posted by clafa View PostI use a Honeywell Vista Panel that was already installed in my house. I bought a piece of hardware “Ad2usb” for $99 and the plugin for Vista panels.
Honeywell also has keyfobs that your “pair” and then you can have homeseer take on the automation piece.
I am by no means an expert on this so read and take it all in...
Laugh when you end up trying for hours to automate something that take seconds
Its the journey that counts
Have a good one
Chris
I am a very satisfied ELK M1G user, so forgive the bias. In my opinion, all security systems are built pretty much the same when it comes to zone hardware, arm/disarm, zones types, wired and wireless - the major brands all meet standards. I've used a few, and I don't see much difference in quality, and my ELK has been trouble for for many years (just replace the battery periodically). What distinguishes them is home automation features and expansion capabilities. That is where ELK or Omni excel. I recommend you do a side by side on automation features for the major brands used by the folks on this forum, and pick the one that has the features you think you might need. The reasons I chose ELK M1G included: the digital outputs doing things like opening garage doors, I wanted my lighting on a stand alone lighting controller that can also be operated by HS, and lots of expansion options.Mark
Hometroller S6 w/ HS3Pro, Way2Call
BLAB8SS, BL Backup, Easy Trigger, HSTouch, Open Sprinkler, SONOS, Ultra1Wire3, UltraM1G, WeatherXML, Z-Wave
I also recommend the DSC Alarm Systems hard wired to its sensors. Along with an EVL4 and the DSC add on, you can pretty much do anything.
DSC has a wired motion sensor that is very inexpensive, (<13$ ea,). If you put them all over the house, you can very inexpensively control lighting and enhance your security at the same time for very little money.
If you haven't bought a security system yet, do not place too much emphasis on the keypads. I use Android tablets and Geofencing for the arming and disarming of my DSC system. In fact I only have one keypad for my alarm system and it is hidden as I only use it for programming.
I also recommend a separate camera system on its own, separate network for security speed reasons. I personally use IP cams. Some are PTZ others are fixed. Then you can stream the cam video to any tablet or mobile device.
If you have any interest in having your own NAS for computer backup, storage, movie database or another reason I highly recommend you look into Synology Surveillance Station for your camera recording. If you do not want a NAS, get a NVR as a Security Video Recorder to make sure your video is being recorded and tagged with motion.
Also make sure your video doorbells are ONVIF compliant so your video recorders can record their video also. This will save you money as you will not need to buy extra cameras at those locations.
Originally posted by Igorski88 View PostOK, i'm convinced on a DSC system and will be starting from scratch. I'm looking for a control panel that has wired and wireless devices connected. Google doesn't help when I type "Newest DSC system" Any recommendations?
Sent from my iPhone using TapatalkHS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events
Plugin's:
- 1 like
Go with a DSC Power 1832 (32 zones) or 1864 (64 zones). Both systems just have 8 zones but you can expand them with additional modules (8 zones per module). These systems are pretty old and very basic but there is no monthly fee and HS supports these system. You will need an interface board, either an IT-100 (serial) or a EVL4 (Ethernet). I am using the IT-100. There is a plug in for the EV4. Maybe I should have gone the EV4 route because the IT-100 has some bugs and HomeSeer doesn't fix the problem/bug.
- 1 like
