I have three high powered outdoor infrared heaters in an veranda. They are connected to a Lutron HomeWorks QS system using a special controller that accepts dimming inputs. So I can set a heater to 50% power, etc. Now there could be a possibility that someone leaves one on by accident. I want to be notified if the heater is left on for more than 1 hour.
So I setup an event to run trigger Every 30 minutes AND this device has been/for at least and set it for On and 1 hour. Problem is it only works if I run the device at 100%. Originally I thought ON meant any level above 0%, but it seems to mean 100% only.
Aside from creating and setting a virtual device when a heater is turned on at 1% or above, is there a way to have this trigger at 1% or greater directly without all those extra events?
Thanks in advance for any advice.
EDIT: Apologies, I now see there is an events specific board. Seems I can't delete this and post there.
