Hello there,
I have been using a Honeywell Z wave thermostat and it works. I would like to program HomeSeer to change the temperature to a cooler temp in the evening and another change to raise the temp in the morning. I have searched but I am probably not using the correct key words for a hit on how to.
Operating System: Microsoft Windows 7 Professional - Work Station
Enabled Plug-Ins
3.0.2.0: Z-Wave
I need to migrate it over to a Windows 10 box and use my HS4 upgrade.
Thank you!!
After digging around I made this but not sure if it will work. I recall trying to set the RGB lights on the switches to be on when my garage door is open and that was a fail. : )
Enabled Plug-Ins
3.0.2.0: Z-Wave
Thank you!!
