I am getting the run around between HomeSeer and Zooz with issues related to t he ZEN20 Version 2.0d S2 Z-Wave Power Strip. Both companies are indicating that they are in compliance with the Z-Wave standard and NO one will take ownership of the issues.
1. On one of my ZEN20's activating SW3 also turns on the indicator in HS4 for SW5
2. On the other XEN20 HS4 is showing indications for SW6 and SW7 turning on and off. I think SW6 and SW7 refer to the two USB ports.
3. HS4 does NOT show all the child items in sequence. Example: SW1 - KW1 and Watts1 are at the bottom of the list in HS4 instead of below SW1. This may be do to the ID numbers that are assigned to KW1 and Watts1.
4. I have deleted both ZEN20's from my Zwave configuration and re-included them. Every time I do include another set of issues crops up.
Zooz is indicating that HomeSeer is not working with them to resolve the issue and HomeSeer is indicating the same of Zooz.
I like HS4 but if the software is not able to work with various manufactures of Z-Wave compatible equipment what good is the Z-Wave standard?
